RiderForums.com Community
Go Back   RiderForums.com Community > Kawasaki Z1000, Z750 & Z-750S > Z1K/Z750 Maintenance
Reply
Thread Tools Display Modes
Old 03-27-09, 06:23 PM   #1
Z1000
Up-And Comer
No oil pressure, I need your help!
I just changed the oil, which I do every spring before I start to ride. I changed the oil filter (Kawasaki brand) and put 3 quarts, 20 ounces of Mobil1 Racing 4T 10W40 oil in my Z1000.
I started it up and the oil light would not go off. I ran it for close to a minute and turned it off. I unscrewed the filter and it had no oil in it. I thought maybe the filter was defective so I got another brand new filter and changed it out. I started it and let it run for 30 seconds or so and the light still did not go out. I waited a few minutes and let it run for 30 more seconds. It still has not gone out and the new filter is empty.
The bike only has 3,600 miles on it and still looks brand new. Does anyone have a clue what might be going on with it?
Thanks in advance,
Mike
__________________
Black 2003 Z1000
Mike's Z1000 Page
Z1000 is offline   Reply With Quote
Old 03-27-09, 06:25 PM   #2
Martin64
Martin64's Avatar
Did you put oil in the filter before installing it?
__________________
ZR-7OA #110
This map is informational only. No representation is made or warranty given as to its content or usability. User assumes all risk of use.
Martin64 is offline   Reply With Quote
Old 03-27-09, 06:27 PM   #3
Z1000
Up-And Comer
No, but I never have before and it has only taken maybe 10 seconds for the light to go off. I don't fill the filter because I have to turn it sideways to install it, so I'd lose most of the oil anyway.
Mike
__________________
Black 2003 Z1000
Mike's Z1000 Page
Old 03-27-09, 06:37 PM   #4
Martin64
Martin64's Avatar
Sometimes a filter will have like an air-lock (like a bubble) and it won't accept the oil. Mine goes on sideways too and I never lose any. If you put oil into the filter to the top (where you see the threads on the inside) and stop, the oil will soak into the filter....that will be enough to work. Just let the filter set for a minute or two and don't add anymore oil to it, it'll be fine...you'll see the oil level will be a little lower. Of course if you "lolly-gag" around while putting the filter on it will drip out. Even though mine doesn't drip, I still keep a rag or pan under until I get the filter on all the way (barely snug + 1/4 turn).
Think of it like priming a pump (which is really what you'll be doing)
__________________
ZR-7OA #110
Old 03-27-09, 06:40 PM   #5
ozzyflash
Up-And Comer
ozzyflash's Avatar
I've been there and done that. On this forum there are others who've been down this path.
What's happened is you lost the prime on your oil pump when you changed the oil. If I had to guess.... I'd say you drained the oil and removed the filter, then waited a while (more than 5 minutes) before you installed the new filter.
The way I handled this problem was I very loosely screwed on the oil filter leaving a gap between the filter and the engine block so that air could escape from the oil lines while I started the engine and let it idle for a moment.
Leaving this escape route for the air keeps the oil filter from essentially pressuring and keeping oil from working its way through the pump.
it shouldn't take more than 5 or 8 seconds of idle before you begin seeing oil leak from the gap left between the filter and engine block. Once you see oil leaking you can go ahead and tighten up the filter.
__________________
2003 Z-1000 in Orange
Mods: Givi windscreen & Z-billet case sliders
ozzyflash is offline   Reply With Quote
Old 03-27-09, 06:47 PM   #6
masalma
Rising Star
Yep, have to do that with every oil change, just loosen the filter, turn on bike, and the second see any oil just tighten it up.
masalma is offline   Reply With Quote
Old 03-27-09, 06:51 PM   #7
Jason 306
Supreme Being
Jason 306's Avatar
+1 my bike lost oil pressure when I went down. I started the bike up, unscrewed the filter a little bit until some oil started to shoot out, tightened the filter back up and went on to wreck another day!
__________________
Jason 306 is offline   Reply With Quote
Old 03-27-09, 06:54 PM   #8
Z1000
Up-And Comer
That worked. Thanks guys! I just hope I did not ruin my motor. With all my screwing around and experimenting, I bet it idled for a total of three minutes without oil pressure. I did have synthetic in it before, so I hope that helped save the cylinders.
I will take it for a spin. I'm sure I will know if I have killed the motor.
Mike
__________________
Black 2003 Z1000
Mike's Z1000 Page
Old 03-27-09, 06:57 PM   #9
Billet Z1K
Authorized Vendor
Billet Z1K's Avatar
Just about put a 45 cal hole in mine because of just this thing
Unscrew the filter a turn or so and fire it up. That will release the air lock and it will start running out. Shut it down, tighten up the filter and re fire. Should be good to go. I always fill my filters but the last time it didn't make a difference. Never had that happen on anything before.
Gary
__________________
'03 Z 1000
'07 1400 Ninja
'08 VTX 1800 N
'08 Brute Force
Billet Z1K is offline   Reply With Quote
Old 03-27-09, 07:33 PM   #10
Z1000
Up-And Comer
I just took a spin for about 10 miles on it. I didn't hurt it. It still runs like a scalded ape and scares the crap out of me. It still sounds smooth and new. I think it's OK.
Thanks again for helping me out.
Mike
__________________
Black 2003 Z1000
Mike's Z1000 Page
Old 03-27-09, 07:45 PM   #11
Jason 306
Supreme Being
Jason 306's Avatar
Mike
As long as you weren't revving the engine without oil pressure, it didn't hurt a darn thing! Trust me
__________________
Old 03-27-09, 07:56 PM   #12
Z1000
Up-And Comer
Quote:
Nope, never touched the throttle. It did idle for several minutes total (not continuous).
How do you like your Two Bros? I have had my eye on the carbon fiber slip ons.
Thanks again.
Mike
__________________
Black 2003 Z1000
Mike's Z1000 Page
Old 03-27-09, 08:03 PM   #13
Shabbernigdo
Rising Star
Thanks again.
Mike
get them there awsome.
__________________
I'm looking at an overhaul, and adding some spray, because if your going to die on a bike you may as well be going faster than everyone else
Shabbernigdo is offline   Reply With Quote
Old 03-27-09, 08:17 PM   #14
Jason 306
Supreme Being
Jason 306's Avatar
Yup I do like mine, I'm not a big fan of their carbon fiber pattern that they use but if you like it go for it. Get the M-5's, I think they look better and they sound great. Nice deep rumble at idle, doesn't sound like any other bike on the road. If you click on the link in my sig and fast forward to the last quarter part of the track video, you'll get a good listen at how they sound rapping through the gears
__________________
Old 03-28-09, 11:44 AM   #15
Z1000
Up-And Comer
If I had the Titanium bike, I'd get the Titanium canisters, but my bike is black, so I think the black carbon fiber will blend better with the colors on my bike.
Thanks again for getting me up and running.
Mike
__________________
Black 2003 Z1000
Mike's Z1000 Page
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2009 RiderForums.com
