| Register | FAQ | Members List | Calendar | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
Supreme Being
ok, guys, now it's MY turn to swap out my rear shock.
is the '03-'04 Zx636 shock still the way to go? is it really a straight swap? I don't think I would know how to modify to make it work.
__________________
Vera Velmerig Cincinnati/Ohio 2006 Kawasaki Z750S (FOR SALE) 1996 Yamaha XJ600 (2002 - 2006) www.motogirlz.org www.scrc88.org Your mind is like a parachute...it functions only when open. |
#2 |
Rising Star
How much you weigh? Going by the picture I'd say yes.
__________________
06 Plasma Blue Z1000 Pigs of Life MC |
#3 |
Up-And Comer
So what does it take to get an 04 zx10 shock on my 03 z1000?
#4 |
Newbie
Sold! Now its time to find a front in for me.
#5 |
Up-And Comer
What is the un-preloaded length on the 03-04 636 forks, in case I missed seeing that earlier in this thread...
I just got '07 6r tubes for my '08 Z1000 , and they measure 29 1/4 static. My Z is sitting under at 28 3/8 , under its own weight. I dont see the 6r fork being that much different once installed. Certainly not an inch of fork above the top crown... Dan
__________________
Dream as if you'll live forever, live as if you'll die tomorrow... '08 Z1000 daily driver, Akra full system race, Ivans's exhaust servo eliminator, Rizoma fatbar, mirror, reservoirs and barends, one-off cnc'd bar clamps, Pazzo levers, Galfer lines, Lightech keyless gascap, OE solo cowl, one-off cnc'd engine covers, '07 ZX6r fork, one-off cnc'd 7075/Ti/Carbon rearsets underway... AMA competition member 1428 Kaw S/C dragbike 1327 Suzy T/G under construction |
#6 |
Up-And Comer
Swapped out the forks today... '07 zx6r tubes are sitting 9/16" above the top crown to match the ride height of the stock Z forks , showing 1/4" above...
0.100" per side spacers added at the axle ( equal to simply using the 6r spacers) , and 0.170" per side spacers added at the lower fender mount. GROOVY. Now I just need winter to go away so I can try er out... Dan Seems that the caliper mounts are a few degrees further away from the stanchions , as well , could use an inch or so more brakeline to accomodate. Its a little tight at full extension.
__________________
Dream as if you'll live forever, live as if you'll die tomorrow... '08 Z1000 daily driver, Akra full system race, Ivans's exhaust servo eliminator, Rizoma fatbar, mirror, reservoirs and barends, one-off cnc'd bar clamps, Pazzo levers, Galfer lines, Lightech keyless gascap, OE solo cowl, one-off cnc'd engine covers, '07 ZX6r fork, one-off cnc'd 7075/Ti/Carbon rearsets underway... AMA competition member 1428 Kaw S/C dragbike 1327 Suzy T/G under construction Last edited by 100monkeys : 02-07-10 at 07:52 AM. Reason: added info |
#7 |
Rising Star
timmer -
are you using the stock Z1000 rotors? |
#8 |
Rising Star
Affirmative
#9 |
Supreme Being
Timmer - Great write up and nice work!
__________________
Ride Naked. COS-M1K 1. of or pertaining to the cosmos: cosmic laws. 2. characteristic of the cosmos or its phenomena: cosmic events. 3. immeasurably extended in time and space; vast. 4. forming a part of the material universe, esp. outside of the earth. |
#10 |
Rising Star
Thanks Nudist, now how about those spy pics of your new creation? I am going to ask at least every week until you cave in...
#11 |
Newbie
Correct me if I understood wrong.
If I want to make the rear shock swap, it has to be from a 2003 636 or else I'll have to switch spring? Is it better to get a 03 shock and use it stock, or buy a almost new 06 shock and switch spring with old device on Z? What are the chances of getting an old shock from a 636 that is not working that well (worn)? If anybody here has one to sell, please advise. |
#12 | |
Supreme Being
Quote:
__________________
#13 |
Up-And Comer
#14 |
Site Elder
1.25" - which is about 30mm.
__________________
2005 Black Z1000 - nicely modded |
#15 |
Newbie
ZX10 Forks
Hi all
As a newbie to bike modifying I was wondering if the fors of a ZX10 are also suitable for this modification? Having troubles finding some 636 stuff in australia. Cheers |
| Thread Tools | |
| Display Modes | |
