| Register | FAQ | Members List | Calendar | Mark Forums Read |
Thread Tools | Display Modes |
#271 |
Rising Star
So far I have ordered
05-06 Fender 05-06 Axle 05-06 Forks 03-04 Rear Shock swap into a 03 Z1000 two spacers? 5. '00-'02 Zx600 wheel spacers; Kawi part #92152-1251 (local Kawi dealer) And 05-06 caliber? or would the stock once fit? rotors? and what other parts would I need? Thanx guy, I went through the thread but too much info ![]() Nas |
#272 |
Rising Star
Your stock rotors will fit. You need calipers from an 03-up zx6, zx10 calipers will work, I picked up 05 zx10 calipers.
#273 |
Rising Star
You will also need longer brake lines
#274 |
Rising Star
#275 |
Newbie
No - you only need the longer bolts with the 03-04 ZX6 front-end as the older 636 has smaller disks.
The standard 05 ZX6 caliper bolts will be fine.
__________________
Scratch and sniff... 2003 Zed 1000 - home made tail tidy, mate-made alloy engine covers, Hindle SS full system, Dynojet PC III, airbox mod, Ohlins rear shock, Hel carbon brake lines |
#276 |
Rising Star
So far I have gathered all the parts for the swap
05-06 Fender 05-06 Axle 05-06 Forks 05-06 caliber 00-02 Zx600 wheel spacers; Kawi part #92152-1251 (local Kawi dealer) 00 gsxr 600 Master Cylinder (get to use my brand new pazzo levers) so all I need now is the brake lines 2000 Suzuki GSXR 600 Master Cylinder 2005 Kawi ZX6r 636 Calipers I would want two lines from the MC at 32 and 34 inches lengths. was hoping to have them in kawi green with black bolts. I contact a few shops that custom make them and they were inquiring about the angles of the banjos. Any clues? Also some shops wanted to know the size of the bolts, I tried looking up online but no luck. Suggestions are appreciated. Thank you, Nas |
#277 | |
Supreme Being
Quote:
![]() Also be warned that if your master cylinder is off a 600, it should have a fine thread pitch rather than a course.
__________________
#278 |
Rising Star
Masalma- I ordered my lines from spiegler USA. They ship to Canada, I'm in Edmonton. They have different colors too..... I'm just waiting for them to get here.
I'm doing the same upgrade. With the 05 forks, you will want to run them 30mm above the top clamp as they are quite a bit longer. If you run them flush your handling will change. Under the general z forum there's a thread called "got my rims back". On the second page you can see my bike with the new forks and how they're raised in the clamps. |
#279 |
Up-And Comer
Has anyone made this work with 2003 636 forks and a wheel form a 2005 636? The axle from the 2003 is much too large for the wheel bearings. Will the axle from the 2005 fit the 2003 forks?
__________________
Ignore all spelling errors, Spellcheck is for cheaters 2005 Z1000 Mods: -Ermax Bellypan- <-KIA, Fender Eliminator, Full akrapovic- shortened can, PCIII, K&N, airbox mod, CRG barend mirrors Unwanted mod: Noisy clutch |
#280 |
Rising Star
I am ordered a set of 05-06 ZX6R EBC HH brake pads, but was wondering is there a difference between ZX6R, 636 ZX636 ? or are they all the same bike?
also picked up a 04-05 ZX10 rear rotor, any interchangeable rotors for the front? that would work with the swap. |
#281 |
Newbie
Spring rate for z1000 with 636 forks
Hi All,
I did my suspension swap a few years ago and I am now looking into the sag... I think I need to upgrade the springs as I get about 40mm with the preload nearly all the way. Looking at the various threads I note the RS117 has utalised a 1.0 kg spring. Can anyone else share what they have used. I have the forks from a 636 2006 model in Silver, so I guess these are 'C' model forks. I also intend the remove the standard spring from the Z1000 rear shock and fit this to the 636 rear shock I have. For information, I am 85kgs |
#282 |
Up-And Comer
Hi folks,
Can anybody tell me if the '05/'06 rear shock assembly is a direct swap in on the '03-'06 Z1000? I've read this entire thread end to end a couple times, and it looks like everybody usually uses the '03/'04 rear shock assembly, even if they use the '05/'06 front end parts. Any light you could shed on this would be great. Thanks.
__________________
#283 |
Rising Star
I am stoked, found a guy who is selling me his 03 forks, axil, and calipers all for $100. This is gonna end up being cheaper than I thought
__________________
2005 Raw Titanium Z1000 PCIII, BMC Air Filter & Airbox Mod, Renthal Ultra Low's 520 -1/+2 Conversion, Hyperpro RSC Steering Damper 636 Forks and Calipers, Tach LED swap w/black face Muzzy Headers, LeoVince GP Can, Pazzo Levers Frame & Swingarm Sliders, Fender Eliminator, TechSpec Coming soon: SSSA |
#284 |
Rising Star
Well I finishled the swap. I did it by myself and it took around 5 hours or so. I still have a little bit of air in the brake lines I will need to keep working out. Would have helped to have an extra hand doing it, but I guess you can say that about any job. Now I will just need to tune the suspesion a little bit. Thanks for all the into throughout this thread, made doing this a piece of cake.
__________________
#285 | |
Supreme Being
Quote:
__________________
| Thread Tools | |
| Display Modes | |
