| Register | FAQ | Members List | Calendar | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
Rising Star
636 Swap complete...my experience
Today I did the 636 swap with both the front forks and rear shock. I wanted to post my experiences to share what worked for me and what didn't, hoping the next person that tries may have a little easier run at it. That is not to make it seem like it is hard because it isn't (easy to say now that it is done).
First, I collected all the parts necessary for the swap. All of these specific parts worked well and were essentially direct bolt on: 1. '03-'04 Zx636 forks (off ebay) 2. '03-'04 Zx636 shock (off ebay, same seller) 3. '03-'04 Zx636 front brake calipers (off ebay) 4. '03-'04 Zx636 front axle (off ebay, same seller as #3) 5. '00-'02 Zx600 wheel spacers; Kawi part #92152-1251 (local Kawi dealer) 6. 10mm radial brake spacers (www.motospecialties.com) 7. 10mm x 1.25 pitch x 70mm bolts for calipers (from http://www.mmsacc-stainless.com/metr...ric_allen.html) 8. Spiegler smoke stainless brake lines w/blue fittings & banjo bolts; specifically made for joining Z1000 master cylinder to '03-'04 Zx636 calipers; +2 inches length (from www.spieglerusa.com) 9. Galpher brake pads (from local Cycle Gear, just know you need two packages worth as there are four pads per caliper) Next I bought some tools for the project, but they will hopefully get used for years to come: 1. Quality Torque wrench with both high and low Newton Meter capabilities 2. Motrax axle tool 3. Pitbull front triple stand 4. Metric hex key set (most of the parts that need torque followed are hex keys) I started by replacing the rear shock from the Z with that of the 636. This was a very easy swap...once I figured out that we should jack up the engine to release some of the tension on the shock. I used a small jack from my truck and it worked like a charm. Simply remove the two bolts, pull the shock out (I went out the bottom), and replace with 636 shock. I followed torque specifications on the bolts, well, on the entire project for that matter. Torque the two bolts holding the shock in place to 34 Newton meters (N-m). If you have to unbolt the dogbones, replace at 59 N-m. Next I started the front. Removed the front fairing, broke most of the stock bolts loose while the bike was still on the ground, and then put in on the front & rear stands. I started by removing the front fender and then the stock braking system (made sure to have wet rags on hand to clean up any stray brake fluid). Next, I removed the front axle with the listed Motrax tool. Took the front wheel/spacers/axle out and then removed the stock forks. I placed the new forks in the tubes and used a small screwdriver device to ensure equally height in the triples. Essentially, we made sure they were exactly the same height by placing the end of the screwdriver in a specified location on both sides and raising the forks until it hit a plastic stopper on the handle. We double, triple, and quadruple checked the forks to ensure equal spacing. 25 1/2mm up is what I went with but that doesn't mean it is right. Torque down per specs; 13 Newton meters (N-m) for upper bolts and 30 N-m for lower. Installed front axle ('00-'02 Zx600) and wheels spacers (see part number above), torque to specs (127 N-m axle for Z, but went with it on 636 parts; 25 N-m for axle bolts). Bolted on front calipers (25 N-m torque per Z standards) with listed spacers and bolts (after replacing pads). Finally, attached the brake lines (again, 25 N-m torque. If you order from Spiegler like I did, I suggest doing +3 inches or +4 instead of the 2 I did (that is length added to their normal Z1000 kit). They are a little on the short side but work fine. This project is so much easier with a buddy or two to help. The entire project took about 8 hours and that included store trips, food, and installing my Motovation frame/case sliders. I had planned on taking pics as I progressed but the battery was dead and most people are more capable of this project than I. Also, there is a little water still on my bike in the pics in case anyone notices a weird pattern. I washed it at the end to ensure no brake fluid all over... Check http://zed1000.free.fr/manuel/manuel.pdf for any help you may need. I used torque specs from the Z1000 even on the 636 parts. My local Kawi dealer said it was probably a safe route to take without breaking out their manual. Don't use my torque specs on the 636 parts unless you believe they are about right or you have no other info to go off of. The internet is your friend and likely has an online guide like the one I linked to. *EDIT* I added the torque specs to make this a more comprehensive guide of my experience. Last edited by timmer357 : 11-19-06 at 01:40 AM. |
#2 |
Rising Star
Last one...the overview
#3 |
Rising Star
Could you take a look at here
Got some questions, you may have an answer for
__________________
mac -------- Red Z750 2005: Barracuda windscreen · Matris forks preload kit · HEL brake lines · Cut stock exhaust · Home made tail tidy · Aprilia Tuono mirrors · Custom mini-indicators · Custom front footpegs · Renntec grab rails · Jack up kit · Renthal Fatbar |
#4 |
Rising Star
iv'e just got hold of a full zx6r 2005 front end with caliper spindle and spacers, will i be needing any other parts mainly spacers and such?
cheers guys |
#5 |
Supreme Being
Vewy, vewy, nice! Love the blue!
Nice recap BTW... this should be an EZ find with a little searching, although for the life of me I can't figure out why it isn't stickied, or put on an FAQ like the SVRider Forums do...
__________________
#6 |
Supreme Being
Great write up and nice look'n pics
__________________
2003 Z1000 Muzzy CF Full 4-2-1 System, VFX Taillight Kit, Ivan's Airbox mod, ZX9R Flywheel,Stator,Cover, ZX636r Rear Shock, Ermax Belly Pan, Black Gauge Face 2005 ZX-10R Akrapovic Ti Evo 2 exhaust with LOR can, PC3, Integrated Smoked Turnsignals, K&N Filter, TRE, Moose Handlebar, Targa Seat Cowl, Race Intake Cam, Degreed Cams 106/104. |
#7 |
Site Elder
It appears you have the stock handlebars. I've always wanted to do this mod but was afraid I wouldn't get enough clearance for the fork tubes to slide up withought them hitting the bars. Any pics of the top of the fork tubes?
__________________
Len - Z1000 Barrie Air box mod, PCIII USB, K&N, Custom BlueFlame slipons, Fender eliminator, LP SS turn signals, PBR frame sliders, Motovation engine case sliders, Kawi taller windscreen, NBM SS front/rear lines, 636 shock, Skidmarx BP, Pazzo levers, Rizoma Circuit 851 mirrors, Corbin seat, Grip warmers, Dual headlight mod, BT014's, and mostly blacked out. Check out our website The Brake's Site |
#8 |
Rising Star
Prozac, here you go although this pic makes it look like it is really close. It is in the ballpark but still not even close to touching. You'll find differing amounts of height in the triples on this forum. I can't tell you which is right or wrong but some simple measurements before and during the operation will help get you close. I spent WAY more time ensuring the forks were even rather than exactly the same ride height as stock.
#9 |
The Parts Guy
I have stock bars and the forks fit just fine.
__________________
748 "Mallard Edition" |
#10 | |
Up-And Comer
Quote:
fit but it's OK |
#11 | |
Up-And Comer
Quote:
the c models, it will fit the b models fork's |
#12 |
Rising Star
Ropehead, from what I have read, you will need to get a new front fender but can eliminate the need for caliper spacers. I believe the 05-06 had larger rotors and therefore is a straight forward swap. You may then be able to get away with standard caliper bolt and not have to order some from across the nation like I did. I spent more on the spacers than needed 'cause I ordered the black ones via Crimson Cloak. There are just a lot nicer looking and I didn't have to drive all over town trying to find someone to machine me a set (thanks for the info Crimson). I can't tell you the other differences as I obviously went with the 03-04 swap. Just start watching ebay and you'll get a smokin' deal on the whole front end.
Anyone have any luck selling the Z suspension after the swap? |
#13 | |
Rising Star
Quote:
I would of thought you could make a bracket to fit the z1000 fender on the 05 zx6r forks. |
#14 |
Newbie
Timmer357, absolute superb write up, many thanks. I have been searching the various forums and related strings and never found one that is so good.
I do have one query, what is the sag like using the 636 forks? Do the fork springs need to be changed to something slightly stiffer to compensate for the extra weight of the Z1000? Or is it a case that the suspension was too hard for the 636 and works better with a bit more weight? I will have a rear 636 shock arriving early next week, just about to bid for the forks. |
#15 |
Rising Star
One of the best write ups Ive seen, top job as well
__________________
Fun is a Black Z1000 Saying hello from sunny England ![]() Uk Z1000 forum http://www.z1000uk.proboards52.com/index.cgi |
| Thread Tools | |
| Display Modes | |
